MA2 Battery charging.
borderpatrol
Newcastle upon tyne
Hi all been out flying for last 2 days since receiving it,loving it,loads of experimenting, gaining confidence and learning lots. Looking for some advice please, have charged all 3 batteries twice now but not used hub yet. Batteries are re-charging at the moment for tomorrow. After tomorrows flights i wont be using it for a few days so do i just charge them up the day before using again or do i need to fully charge them after use tomorrow? Never used this type of Battery before so just need to make sure i am doing right thing as replacements are expensive! cheers.
Reactions: old man mavic
its ok to put them in the hub to charge them once you have charged them once one at a time it will charge them up depending on how much charge is left in them one at a time till they are all full as long as you have around 30 to 60% charge in them after your flying is finished then they will be fine to store for a few days then just charge them the evening before your next outing apparently they have a new feature now that drops the 100% charge down to 96% after 24 hours after applying a full charge dont worry if this has happened before you use them as 96% is plenty to get a good flight in just remember to number the batteries so you can keep track of their usage
Thanks for the quick reply, batteries are all numbered(dymo taped) and have been rotating them use wise. Will use hub later in the week for what will be the 3rd charge for these batteries. Many thanks.
OsageCoach80
