Just wanted to share a recent experience that I had with the Air. Broke out the Air after a few days of traveling. Want to fly it for some aerial video at a kite festival. So I took off, straight up to clear some kite lines and noticed that I was at 60% battery. They warning told me that batteries were in a discharge state. I watched the battery and it seemed to be holding the charge just fine. After some video I thought I'd fly up high and down the beach. As I was doing this, I got a 30% low battery notice. What I had not considered was that my timing was off. I started at 60% and the Air has a short flight time. I started to come back and then also kicked it into Sport mode. I was around 200' away and around 15% battery. Something I did not think about.... I needed to be _directly_ overhead before I even started to come down as I only had an area of about 50' around where there were no kites or lines. I started to panic a bit as I did not want the Air to start landing at 10%. There were a lot of people and kites in the area. At this point, I was about to piss myself. I got the Air down o around 200' and managed to find it in the sky after 10 seconds or so. I landed with just over 10% battery left.
There were three errors I made... I took off with less then 100% charge. The issue was not the charge itself but that this made error 2 worse. Second error was that I failed to remember that I was flying the Air with less flight time. Last error was becoming a little laid back in flying around people or objects. I should have realized that launching in such an area meant it would be much more difficult to land.
Something to keep in mind.
