Magnetic Cable Help
nfarruggio
Hello,
I recently purchased magnetic charging cables with adapters that remain in the various devices I charge. Because I have the adapter/plug in my phone which I use for flying my Mavic I would like to use a magnetic cable to connect my RC to my phone from the bottom USB port so I don't need to keep taking out the adapter/plug. The ones I purchased apparently do not transmit data over the cable (despite advertising that they do). Does anyone have any suggestions for a particular magnetic cable that would work for this?
-Nick
An alternative is a 90 degree cable at both ends - less magnetism around drones is better due to calibrating
Reactions: WAXMAN
I think your problem is because the cable does not have enough terminals/contacts.There are cables with only 3 contacts .. used for charging and there are some with 5 pins .. data as well.
First image shows 5 terminals and image 2 only has 3 terminals.
Reactions: WAXMAN
Hmm. The one's I own have 5 pins...
If you are flying a Mavic Air you have to remove the cable from the left side of the RC when using the USB port in the middle of the RC
kholik ibnu
