I'm having problems with the Mavic drifting quite a bit instead of hovering in one spot. I put it in tripod mode and it's still drifting a lot. I tried to calibrate the sticks on the remote. Instead of having 0% on all positions my right stick, while in neutral, it indicates 8% on reverse and 7% on right side. Before I hit the actual calibrate command it indicates all 0% but once I hit the start command that's when the 7% and 8% shows. Also I couldn't get the calibration process to ever complete. It kept timing out.
Anybody have input on why the calibration process will not complete? If it does complete will that indicate all 0%'s on the stick while in neutral? Will calibrating the sticks even fix the drifting problem.
All help is greatly appreciated!!
Sent from my SM-T280 using MavicPilots mobile app
