Maps and waypoints issue
Greg Hay
New Zeazland
Newbie alert. I have been visually plotting courses of complex flights from supplied KMZ files. Been all good until today when I zoomed in on the satellite view only to find the area obscured by cloud. If I can't pinch in to see the topography I can't plot my course from referring to the KMZ. Is there a way to either get a new, cleaner satellite map to use or better yet import the (removed by moderator) KMZ itself? Could really use a hand.
If you are using Google Earth, you can look at imagery from other dates to find a better one.
Welcome to Mavic Pilots!
You can use MOBAC to download a USGS TOPO of your area and convert it to a KMZ. That then becomes a layer which you can easily enable/disable from GEP and see altitude heights. That's what I do.
Welcome to Mavic Pilots from Dayton Ohio USA! Fly safe and have fun!
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
tagir
