Massive errors. pic inside
icantdo55
Error code3
Checked all connections to main board and all look fine. Camera works but is constantly trying to go up and to the right so much the camera gets hot like 170*F hot. Unit activated and loaded firmware fine.
Any ideas?
It was a brad new unit that had a DOA main board and a new one was swapped into it,
Brand new unit, swapped main board and no option to send it back?
Welp, Start by trying a new main board for a second time and it sounds like you’ll be spending more on top of that
Yea I'm thinking that too, already sent message to guy I bought board from on eBay. Just was hoping it was something simple.
This is very old... but.. For anyone else.
If you swap the main board you will likely also need to find a DJI shop that will re-flash you Mavic Air to enable the different gimbal to communicate. This goes the other way around as well if you swap out gimbals. Seems to be an effort to prevent DIY repairs..
DanCan
