I am experiencing what I consider unnessary and excessive vibration from the Master Airscrew props. This is in reference to a Mavic Pro Platinum with landing leg extensions.
This all started when I noticed the left landing leg was cracked at the base. I was dumbfounded as to how this happened! I have flown over 350 flights with absolutely no crashes and bad landings. And I know I have never banged into the door on the way out. I am obsessively careful with my Mavic. The only thing that changed was I had switched to the Master Airscrew props during the last 30 flights or so.
After fixing my cracked leg with cyanoacrylate glue, it crack again on the next flight with MAS props. So I fixed it again and then switched back to the DJI 8331 props. No more cracking after my latest 10 flights. So yesterday, I switched back to the Master Airscrew props to see what would happen. It cracked again after one flight. Ah Ha!
So I did a little experiment (should have done this earlier). I have included a link to my YouTube video with my observations.
Your mileage may vary, but my observations are:
1) Master Airscrew props exhibit a greater vibration than the DJI 8331 props. Visually and by touch.
2) With leg extensions, the Master props MAY cause structural cracks in the legs. Without leg extensions, probably not.
3) The reason for the difference in vibration level may be many things... imbalanced prop... different architecture... bad batch? I do not have the right instruments to balance a prop. However, I shouldn't have to.
Bottom line, the Master Airscrew props will probably be OK for most drone configurations. For me, I'm going back to DJI 8331's. Try the touch test yourself and make your own determination.
