- Joined
- Apr 13, 2018
- Messages
- 140
- Reactions
- 60
- Age
- 61
I have found nice improvements in flight and control after adding MAS props in the past however the MAS props for more recent DJI products are claiming very little other than a better pitch / sound. Chalk that up to DJI designing more efficient props that closely resemble that of Master Airscrew.
I have MAS props for my Mavic 2, but I haven't used them very much and went back to the OEM props. I perceived a loss of response, but could have just been my imagination. Perhaps it's sime to break them out again to see if my impressions are different.I have found nice improvements in flight and control after adding MAS props in the past however the MAS props for more recent DJI products are claiming very little other than a better pitch / sound. Chalk that up to DJI designing more efficient props that closely resemble that of Master Airscrew.
So the only real reason to buy the props for the Mini 3 Pro is because you like the color...... I think DJI is missing out on a profitable add on item by not offering colors.
I had some orange ones in my kit for my Mavic 2 that I had flown with only a couple of times. I thought it was time to break them out again. They're back on the biird, waiting to get a little more charge on the batteries and hope to get out and fool around... err... practice to see how, once again, I like them.Have ordered a set of orange props, once installed and tested will give my thoughts, the specs look good and the colours make the drone more visible, I use the MAS props on my Air 2s and they work well.
Where was that established?It's been established that the MAS props are not as durable as OEM props. Tried them on my Air 2s
but took them off. Waste of money IMHO.
I have sets of both the orange and green on the way.I hope that a user who owns this Props makes a test and share his thoughts with us.
I had them on my Air 2S. A slight bump of the props upon landing caused fractures. The same bumps with OEM showed no damage. The MAS are made of just a little stiffer plastic. The truth is, they are not any more quiet. They offer no more flight time nor top speed. The handling is the same. They do sound quieter due to the lower tone. They ARE good props and the various colors look good. It is a personal choice, and either is a good one. They are just as durable as OEM, as long as you keep them clear of contact.Where was that established?
Link?
