Mastershots format
Moura
Hi its is possible in Premiere PRo EDition remove the color profile of Mastershots? Thanks
I didn't realize Mastershots had a color profile. However, you can manually adust the color, exp, etc.
I do not know if its called color profile, but the color is much more saturated than normal footage... and in edit i would apreciatte some way to eliminate it. Thanks
Maybe it is because in the normal mode you use D-Log as your color profile, which is very desaturated, it is meant for heavy color grading. I don't have an Air 2S so I don't know if D-Log is available in Mastershots.
dojin23
