Mavic 2 Dual Enterprise (Will Not Work With....)
Marksnet
Chipley, Florida 32428
Helllo all,
So I’ve been using Drone Deploy for mapping and roof reports.
All of a sudden it doesnt work anymore and DD says they do not support the Mavic 2 dual enterprise Drone yet.
However it worked for 3 months.
It gives a remote controller error.
I’ve toggled every item
I’ve change multiple flight mode on and off on the DJI pilot app for the drone
I’ve uninstalled all apps
I’ve powered down and back up.
So I figured maybe GS Pro from DJI would still work.
NOPE
DJI doesnt even support their own drone.
Error with DJI GS Pro
No camera recognized.
Can anyone recommend a software that will support my drone and allow me to fly by autopilot and a grid pattern that will allow me to generate roof reports like Drone Deploy used to do?
So bizarre!
Reactions: jvhooser
Pix4d is the other most common flight software available...
NOPE
You must use GSPro 2.0.3
That version supports M2ED
Reactions: mavin
Contacted DJI and they confirmed GS Pro still does not support Mavic 2 Dual Enterprise
Hmmm, that sounds irritating ...
Just came back with the M2ED and GSPro 2.0.3
It worked with a waypoint mission. i selected the Mavic Enterprise camera with 24 mm.
Your AC is not connected
  • Wow
Reactions: mavin
Hello,
I'm facing the same issue as you concerning the compatibilities of the ME2D and flight planning apps and it's really annoying! Did you figure out the best solution ?
Thank you very much !
Preliminary testing of GS Pro 2 with the M2ED indoors. Connects to the M2ED recognizes it as a Dual. Can access the visible camera but not the thermal camera nor the mounted accessory. While I can seamlessly switch back and forth (without shutting down the drone or controller) from GS Pro 2 to the Pilot app to access the thermal camera and accessories, I'm not sure how well that would work inflight in the middle of a mission. I will test it later outdoors. I do like the ease of setting up missions with GS Pro 2.
lschabert
