I have a Skydio 2 broken motor shaft. After a crash I trued bending it back. Since it is hard steel it just snapped off.
I am planning to pull apart a Mavic 2 Pro Zoom motor but I don’t see a Cir clip or a Screw to remove the bell.
Once the bell and shaft are detached I should be able to press the shaft free.
The shaft diameter is 3mm, and may be a close match with the Skydio.
Skydio motors replacements are still a mystery I guess, and Skydio requires all jobs to be in house, no DYI and they do not volunteer specs.
Aside from using a Mavic motor shaft as a starting point, I will be seeking anyOne with a lathe to fit the profile of length and cir clip groove and land for adapting it if even possible.
So, does anyOne in Droneville have a lathe and carbide tooling?
I need guidance on how to get the mavic motor disassembled.
