Mavic 2 Pro cable for iPad
amphallang
So I’ve been searching trying to understand what I’m missing here. I understand the side port on the controller is not a special connection just square (micro usb). I’ve read here the I could use the Apple cable on the USB port ( in the center of the grip) to connect the iPad but I get no connect to establish from that port. What am I doing wrong? Or can someone recommend a cable solution for using an iPad, Thanks!
Reactions: BurninCoco
Thanks... it works now. You guys are awesome! Guess I can cancel all those cable I ordered from amazon...
Reactions: Porky
Actually, you can use the side port and the bottom port at the same time. BUT only if you use the side port for charging including using a power bank. At least, that is what I've read here!!! (g) Folks have gotten extended power from the controller by attaching a power bank.
You are right, just tried it;)
Reactions: ff22
What one did you try porky?
“I’m almost done give me a minute” or
“I’ll be there in a minute”
Great news on the charging at same time as using the USB port at bottom
Reactions: ff22 and Porky
Use your imagination ???
Reactions: Smalls
hughesthis
