It's not that black & white... the RC1A creates both a .txt & a .DAT log, the RC1B creates only a .txt log.
Mobile device DJI .txt logs
These logs are created by the standard DJI SDK and run from motor start to motor stop (or signal loss), recording telemetry transmitted from the aircraft to the RC at 10 Hz in a few hundred data fields. These logs don't include any raw sensor data - only the IMU solutions that are the output from the sensor fusion algorithm. They also include battery data, gimbal and camera data, flight status and error flags, but no motor data.
Mobile device .DAT logs
These contain a subset of the aircraft DAT logs, including most of the raw sensor data, recorded at a lower data rate of 10 Hz. They are also started at aircraft power up and closed at aircraft shutdown, provided that the app is connected - otherwise it will be the subset of that duration when the app is connected. Not as good as the aircraft DAT files, but nearly as good for most needs.
