Mavic 2 Pro Litchi changing exposures
Rogerc
Gilroy, California
In DJI GO 4 I have it set up so when I push the 5 button switch on the controller up it changes the EV exposure up and down.
When I try and do this in the Litchi app it changes the ISO settings up and down.
How do I set up Litchi so that the EV exposures change up and down with this button?
As a side question, how do some of you have your 5 button switch set up that helps you while flying?
I have the the switch to the right set enable/disable auto exposure and the when I push the button it auto focuses.
What is your set up that you like?
RC
Use the right wheel to change exposure. I wasn't sure of the answer, but I was doing a test flight with Litchi just today with the ISO at 100, the shutter at 1/50 and needed to change exposure. I could see that as I turned the right wheel the aperture changed and everything else remained constant. See subtitle data which illustrates the exposure changes. vlcsnap-2021-04-15-21h35m56s033.png
bin36iyah
