All the usual metadata are present, including GPS position data:Here are some photos from the drone.
Interesting, sar104, thanks: now 3 questions, please.All the usual metadata are present, including GPS position data:
ExifTool Version Number : 12.36
File Name : DJI_0771.JPG
Directory : /Downloads
File Size : 7.2 MiB
File Modification Date/Time : 2022:03:20 21:20:59-06:00
File Access Date/Time : 2022:03:20 21:21:01-06:00
File Inode Change Date/Time : 2022:03:20 21:21:00-06:00
File Permissions : -rw-r--r--
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Description : default
Make : Hasselblad
Camera Model Name : L1D-20c
Orientation : Horizontal (normal)
Samples Per Pixel : 3
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : 10.00.14.06
Modify Date : 2022:03:10 13:04:07
Y Cb Cr Positioning : Centered
Exposure Time : 1/500
F Number : 5.6
Exposure Program : Program AE
ISO : 100
Exif Version : 0230
Date/Time Original : 2022:03:10 13:04:07
Create Date : 2022:03:10 13:04:07
Components Configuration : Y, Cb, Cr, -
Exposure Compensation : +0.3
Max Aperture Value : 2.8
Metering Mode : Center-weighted average
Light Source : Daylight
Flash : No Flash
Focal Length : 10.3 mm
Warning : [minor] Bad MakerNotes directory
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 5472
Exif Image Height : 3648
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
File Source : Digital Camera
Scene Type : Directly photographed
Exposure Mode : Auto
White Balance : Auto
Digital Zoom Ratio : 1
Focal Length In 35mm Format : 28 mm
Scene Capture Type : Standard
Gain Control : None
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Device Setting Description : (Binary data 4 bytes, use -b option to extract)
Serial Number : 0K8TFCT0024051
Lens Info : 28mm f/2.8-11
GPS Version ID : 2.3.0.0
GPS Latitude Ref : North
GPS Longitude Ref : West
GPS Altitude Ref : Above Sea Level
XP Comment : 0.9.142
XP Keywords : single
Compression : JPEG
Thumbnail Offset : 21142
Thumbnail Length : 19601
About : DJI Meta Data
Format : image/jpg
Absolute Altitude : +188.03
Relative Altitude : +0.00
Gimbal Roll Degree : +0.00
Gimbal Yaw Degree : -99.00
Gimbal Pitch Degree : -1.30
Flight Roll Degree : -0.70
Flight Yaw Degree : -96.50
Flight Pitch Degree : +2.10
Cam Reverse : 0
Gimbal Reverse : 0
Self Data : Self data
Version : 7.0
Has Settings : False
Has Crop : False
Already Applied : False
MPF Version : 0100
Number Of Images : 2
MP Image Flags : Dependent child image
MP Image Format : JPEG
MP Image Type : Large Thumbnail (VGA equivalent)
MP Image Length : 542258
MP Image Start : 7049600
Dependent Image 1 Entry Number : 0
Dependent Image 2 Entry Number : 0
Image UID List : (Binary data 66 bytes, use -b option to extract)
Total Frames : 1
Image Width : 5472
Image Height : 3648
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Aperture : 5.6
Image Size : 5472x3648
Megapixels : 20.0
Scale Factor To 35 mm Equivalent: 2.7
Shutter Speed : 1/500
Thumbnail Image : (Binary data 19601 bytes, use -b option to extract)
GPS Altitude : 188 m Above Sea Level
GPS Latitude : 42 deg 1' 43.76" N
GPS Longitude : 87 deg 44' 33.02" W
Preview Image : (Binary data 542258 bytes, use -b option to extract)
Circle Of Confusion : 0.011 mm
Field Of View : 65.5 deg
Focal Length : 10.3 mm (35 mm equivalent: 28.0 mm)
GPS Position : 42 deg 1' 43.76" N, 87 deg 44' 33.02" W
Hyperfocal Distance : 1.71 m
Light Value : 13.9
I use ExifTool running on Mac Unix.Interesting, sar104, thanks: now 3 questions, please.
1) how do you extract them listed as above
2) are GPS coordinates also available in Mavic 2 Pro videos? I found them in pictures.
3) are GPS coordinates also available in Mavic 1 photos and videos?
Again, many thanks in advance
Many thanks!I use ExifTool running on Mac Unix.
All DJI aircraft include those data in photos. Video files do not have embedded position data for each frame.
