Mavic 2 Range Test
continuecrushing
So I usually do range tests with my new drones to see how far they can go, but typically more for what the video feed looks like. I put this in both the zoom and pro sections of the forum, as I technically tested both but this video is based only on the zoom. I suspect the distances for both should be about the same.
Now the first test I did with the Mavic 2 Pro didn't go as far-but that's because when I was checking my screen record later I realized that I started with a battery at 79%. Not sure how that happened, but I guess I forgot to top off the battery after an update I suppose.
How far were you able to track it before you lost visual LOS? This MP2 is like a stealth. I'm having a hard time tracking it compared to the phantom lineup.
jc_bromley
