Mavic 3 classic
Hi everyone, new to the forum, my regards from Portugal
(Also new to drone experience)
Any help about what to start reading and the way until start hacking the machine?
Thanks in advance
Alf1973
Welcome! I have many Portuguese friends who sang with me in our church choir!
You have a beautiful country that would look great from the air. Have you bought a drone? What did you get? What would you need to hack?
Welcome to the forum from the beautiful woods of Maine, USA!
There’s many videos on YouTube that start with unboxing and get into your first flight. Flytpath is someone I used when I first started. There’s many knowledgeable members on this forum willing to help you with any questions you have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Since you live in Portugal, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic 3 Classic, including the User Manual.
Fly On and Fly Safe…
nikt_elo
