...Would appreciate help interpreting what happened so that it doesn't happen again. Thank you.
I'm not sure I saw that. But it's possible that I missed it. You think it was headed "home"? In future, I should set the home point at the start of every flight?
Sorry for your loss, but I'm afraid that you should have had some kind of incident sooner or later anyway, your comments really indicate that you don't know the very basics around drone flying & you unfortunately started to seek info first after a incident.
This time it wasn't a classic newbie error though, you barely missed out on those about recorded HP & enough locked satellites... instead it was another famous pilot error that actually happens even more experienced flyers that haven't bother with
"How can DJI drones fly so stabile & hold position even though the drone is affected by heavy winds".
If we start from the beginning of the flight...
It's apparent that you didn't knew the importance of a HP & a proper sat.lock... you took off without any of them. What saved you from consequences from that was that you stayed just about 10ft above the launch spot & didn't fly out until about 92-95sec into the flight, this was where the GPS quality was good enough to have a HP recorded... so a lack of GPS support, HP or VPS sensors not functioning hadn't anything to do with your incident.
In below chart with the synced 2D sat pic. with the flight path & drone icon with indicated yaw direction... I've placed the chart marker at 94,8sec, it's then the HP is recorded, & the drone icon show that it's still above the launch spot (And even though it looks like the flight was above the high building, it was conducted behind it much lower...)
All goes then without drama... until 123sec. There you have ascended up to 19ft & the drone started to be affected by winds & needed to counteract in order to hold position. It's here the drone quickly gain speed & starts to fly away uncontrollably... reaching a heading speed of 34,3mph.
(Click on the chart to make it larger, the legend under the chart explain the graphs & shows values from where the chart marker is placed)
All that happens from 123sec into the flight indicate that your drone had a "Yaw error"... simply said, your drone didn't know in which direction it was pointing, this caused the flight controller to counter the affecting wind with the wrong motors. The cause to this error was that you powered the drone on in magnetic interference.
Investigating the velocity deviation between the GPS & the IMU should normally show values very near to 0mph... If there is deviations it indicates usually either a IMU failure or a yaw error...
This is how it looks when the incident starts...
The Green graph shows that the deviation in an easterly direction reaching as much as 13,4mph
The red graph shows that the deviation in an northerly direction reaching as much as 11mph
So this was very likely a plain yaw error incident... which is totally pilot related not knowing how to make sure all is good before take off.
If you want to learn how to avoid this & learn why this error happens, read this post -->
My bad or not ?
