Mavic 3 signal loss
If you have a chance to take another look -- a few suggestions for you:
  • Double check that you were at the correct location (49.22393698287174, 19.12733146999066).
  • Take a close look on the ground around that area. Your drone could be sitting behind a fallen tree or covered with leaves.
  • Take binoculars so you can easily see the trees from the ground. The foliage doesn't appear to be too dense, so you should be able to see most angles from the ground if you walk around the trees.
  • Love
Reactions: RodPad
I spent 3 hours there. Around the coordinate point, I checked a circle with a diameter of maybe 150m. The drone really isn't there. It is definitely not on earth. It is quite a large drone with a different color than the leaves on the ground and trees.
The night after it was lost, it was blowing hard, I think it could have been thrown from the tree if it had stayed there.
I think there are no coordinates on the point.
I'm not sure what else to recommend as the data in your flight log is pretty straightforward. Perhaps it's sitting high up on top of one of those nearby trees.
Reactions: RodPad
I don't understand what you mean
Sorry, the members that analyze the data.
If one thinks another made a mistake, they will take over the thread, REALLY. Thumbswayup
It is still on earth, It has to be close. 👌
Rod ..
@pat6
I believe you on that.
I lost my first drone P2V+ ($1400) July 2015 40hrs total between 5 of us looking and lot of fuel etc.
Flight logs then. :rolleyes:
I really not sure if they were available.
Haven't found it.
Never again!!
Marco Polo, I would have found it in a hour.
Never again!!
Rod ...
Hello, yesterday I was going to walk again, since the leaves had already fallen from the trees, to the place of the last coordinates. Well, now I'm a little ashamed, but the drone was about 7m from the last coordinates, on a tree. I was very pleased. I was there a total of 4 or 5 times and I also inspected the place with a second drone (I bought another mavic 3), apparently it was somehow behind the leaves when it was not visible from the ground.
Anyway, I took it down today, it was about 17m high...
To be sure, I took it apart, let it dry. I put a battery in it a while ago and it works. :D The lenses are a bit foggy, I'll see if it dries by morning. I also disassembled the photo and let it dry. I will put silica gel bags with him at night.
The battery started to charge, but I didn't give it much sleep, it was completely dead.
Anyway, I'm very happy, and I'm surprised that it works.
Well, at least one of the few similar stories ended happily.View attachment 178954
Glad you found it! Congrats!
@pat6,
You made my Day!
You posted you found it.
You included a picture.
These guys, don't get paid to do this, payback is knowing they helped out somebody!! Thumbswayup :)
Rod ..
Reactions: pat6
elitewikipublishers
