Mavic Air 1 controller - bleeping continuously
I had the same issue occur in about the same time frame of usage of My Air 1. It finally came down to recalibrating the sticks. Not hard to do. The set up for doing it is in the settings portion of the Go 4 app. Once completed all beeping/errors went away... for a decent amount of flights anyway. When the issue came up again and with more research it seemed that quite a few of the MA 1 controllers would do this after about a year or so of use. In the end I have simply surrendered to the fact that I am going to calibrate the sticks whenever needed. I did find a good post on You Tube showing how to take apart the controller and possibly make a permanent fix but it seemed way to much work and possibility of screwing things up even worse. Hope this helps you. Safe and happy flyin'!
This is what works for me.
genoavoles
