Mavic air 2 battery led’s rotating
Matt2155
South Yorkshire, Uk
So after returning from a flight tonight I set my mavic air 2 down, removed the props and powered everting up just to quickly review the images taken.
The battery had about 40%. As I went to turn the drone off it beeped three times then the led’s began flashing in a clockwise sequence.
i tried a second time to turn the drone off with the same result. The dji fly app showed the drone had disconeccted. After a minute of two (after contemplating just pulling the battery) pressing the butting then holding it down worked and it turned off.
Has anyone experien
Has anyone experien
Is it possible you accidentally held the power button down for 4 Seconds and it started it Remote Connect to the controller ?
Thanks for the reply. I have just watched the dji video on linking the controller and this is the same noise my aircraft made. I presumed the linking was all done via the app. At least it’s nothing to be concerned over. Thanks ?
Reactions: Phantomrain.org
Dispatcher
