Mavic Air 2 camera replacement
Dromine
USA
Recently replaced my camera after a crash. Replaced complete gimbal assembly. Now getting IMU warnings and it won’t recognize the camera and gimbal. Also will not calibrate and is off kilter. Does anyone had any experience with this?
You really should have done some research on this before doing the repair, as of right now there is no way to pair the gimbal to the drone if you don’t have DJI software to do so.
the good news is you can still get it to work if you follow the video above.
if you want to completely clear the nagging message after you get it to work you can also send it in to a service center who is capable of pairing it.
Another way is to transplant your OLD camera module back into the new gimbal arm. It has been done and is doable. But this assumes is was not damaged.
lastly there was one time I recalled someone managed to get online support and DJI remotely did something to pair the gimbal, I can’t recall properly where or how.
xtmc13
