Mavic Air Battery Repair
thechev
Arkansas
I am trying to repair 2 Mavic Air 2375 Mah batteries to get them to charge. Kind of like a "jump start". Does anyone know which pin outs on the battery are the primary + and - leads?
The problem you face is likely to be that the battery's control board, ( BMS ) has disconnected the charging terminals from the actual cells, if so external charge can not reach the cells.
Even opening the battery's case and charging the cells directly is no solution, the BMS needs to be reset.
I face a similar problem with an M2P battery I left too long, grrr.
Have a read of DJI Battery Killer repairing tool
I have just tried that but it isn't working for me (((((((
The above said, there is risk in this, the battery cells may be damaged so if you manage to resuscitate the battery I wouldn't trust the battery before you put it through several full usage low hovers over a soft landing site. and even if it 'passes' I would still be wary of the battery.
Reactions: Kilrah
Yeah... I'm probably wasting my time. I've got 2 good batteries. Just thought I might be able to bring the other 2 back to life after watching a video. No big deal.
Not sure of how accurate this is as I have no first hand experience, but happened to find this via Google Search. Best of luck.
Source:
There is a Chinese lithium battery manufacturer named 'HSBATT' that lists on AliExpress. They make the multi-cell OEM battery packs plus BMS board for most of the older DJI drones. I've used their products, which for me have been faultless, and have no hesitation in recommending them (if you can track 'em down).
Please use caution and take a good class on batteries BEFORE trying to use the Battery killer repair tool -- your unburnt home will thank you.
Reactions: cameracamel
A very dangerous undertaking especially if you don't know what you're doing!
Did you mean HSABAT and not HSBATT?
Dispatcher
