- Joined
- Apr 4, 2019
- Messages
- 8
- Reactions
- 0
Hey Guys!
It seems that the downward sensors of my Mavic Air are not functioning properly.
Normally, when the drone lands, it should detect the ground and land gently. Alternatively, when I try to touch its bottom during flight, it should detect my hand and move higher a bit.
The problem is that my drone seems not to detect obstacles from below. For example, it does not move away when I try to touch it from below and it lands quite roughly in autoland, as if it cannot recognize the ground itself...
The drone is running on the most recent FW and I use the latest GO4. The only thing which is not up-to-date is the flysafe database, but that should have nothing to do with this.
What I tried so far:
I recieved no error message on this via GO4. The drone is ca. one and a half years old, and was not crashed.
A couple of months ago it already happened to me once, but at that time a DJI GO4 upgrade solved this issue. Now, no software upgrade is available and reinstalling does not help... I guess it is only some kind of software malfunction, but I have no other idea how to fix it...
Does anyone had the same issue? Any ideas?
Thanks!!!
- Cleaning the sensors
- Turning sensors ON/OFF from GO4 multiple times
- Reinstalling the FW
- Reinstalling GO4
- Calibrating the sensors via Assistant 2 - it completes succesfully, I even see the picture of the bottom camera while calibrating
- Calibrarting the IMU
Thanks!!!
