Mavic Air "drifts"
spamgnome
On a few flights recently, I've noticed that in a hover, the Air sometimes drifts in a random direction. I can stop it, but shouldn't it hold position? While not completely still, there has not a been a ton of wind. Maybe I need to re-calibrate something?
Calibrate the IMU and compass. Most likely it's the IMU. But when you have calibrated the compass, check to see if it is correctly reporting yaw. I recently recalibrated the compass on my M2P because it was off by around 15° and noticeably crabbing in flight as a result. The first two calibrations didn't fix the offset, so I tried rotating the aircraft CW rather than CCW during the calibration process - that fixed it.
Reactions: gizmosforall
When I filmed a small creek the other day my MA did the same thing. I also know I was flying in a location that had limited satellite connections. I figured the random drifting was caused by that and the flowing water.
Here's another suggestion; are you inadvertently resting your thumb on the right joystick making it move laterally? I only ask is that what was happening to me and I never knew I was even doing it :)
What happened in my case was that the controller kept making a beeping noise when starting up also I noticed the drone drifting when hovering. I calibrated the IMU but that didn't solve the problem. After calibrating the controller everything worked fine. Utube shows how this is done.
Ha! Yeah, I had the same idea...but that wasnt it.
Thanks...I too noticed the beeping. VERY loud, right? After restarting the controller, the noise would go away...guess I'm surprised that the app didn't report anything awry
Indeed the noise did go away after taking it up in the air. It reacted a little peculiar though and after calibrating the controller everything worked fine.
The fact that no report or message on the display was given drove me nuts for a while.
My Mavic Air controller requires calibrating fairly often for some reason. I've had the gimbal wheel control bank from time to time also. Calibrating has always corrected the problem. Usually you get a red light and a constant beep as stated by Roosart, but it has acted up in flight as well and then generally required calibrating before the next flight. I've also experienced drift at altitude that Airdata indicated had been caused by high winds (30 kts) at a 90degree direction.
Calibrate the IMU then calibrate the drone, A remote possibility is the drone may need demagnetizing , search cFixer on YouTube. Good luck and fly safe
I recently did a hover a night and it was drifting a lot from lack of downward vision (flow sensor) assistance. Have you ruled in or out this factor?
It could be the controller's fault. If the calibration does not help, and there are incorrect values in the calibration menu, it may be the fault of the potentiometers. This is common. You can replace it yourself, or you can pull out and clean it with isopropanol. I was fine, but sometimes the drone started drifting. I watched the values in the calibration menu and noticed that sometimes at 0% it shows 20% (or it beeps after turning on). After cleaning it is perfect. There is a movie how to do it, or the whole part itself costs about 20 euro.
I have written earlier about problems that I have had with calibration, drifting, and gimbal wheel controlling right stick horizontal movement at times on my Mavic Air. I finally sent the drone and controller to DJI and they've replaced several components in the controller including the gimbal controller. It had always given me cause for doubt. It finally became impossible to calibrate to 100% in all directions, but it would act like all was well and start up and fly only to require calibration before the next flight. I'm anxious to fly it again.
cbooth
