Mavic Air Fly Away with Log
Can the compass error have been caused by my error and not having performed the proper pre-flight procedures. Note: I did not have to calibrate the compass prior to take-off on this flight.
The problem was that you powered up the aircraft in a magnetically distorted location, and then moved it or turned it:
At takeoff there was a yaw disagreement of nearly 160° between the IMUs and the compass. Looking at the magnetic modulus it appears that the entire first part of the flight was in a distorted magnetic field. The modulus really spiked at 151 s, causing the error.
That didn't matter while it was flying under VPS, but after the NavHealth rose enough for it to switch to a GPS-driven P-mode then uncontrolled flight was inevitable:
Interestingly the FC managed to reconcile the yaw error at around 164 seconds, bringing it back under control - I've not seen that before:
The magnetic environment was so compromised that the usual test – is the aircraft orientation arrow pointing in the right direction at launch – may or may not have worked. It most likely wouldn't have been correct though. To that extent I'd classify this as pilot error, although nowhere does DJI recommend that check.
Thank you for the very informative analysis. Lesson learned, and I was fortunate enough to not have lost or damaged my drone.
Thanks again
Erik
Thanks again
Erik
That also looks like a really crowded tourist spot. Not the best place to be flying if conditions aren't right.
NY NICKY
