Mavic Air found in Mattawa, Ontario
You need to contact DJI and give them the serial number. They will notify the owner. you can also report a found drone at the FAA's Drone Zone.
@Cafguy
This is his first post, could you share some links. :)👌
Rod ..
Sorry good point RodPad
Report a found drone here
Reactions: RodPad
@Kilroy2025
I few other things.
If you look close in the battery compartment, there could be something marked in there, i doubt it.
If you pull the SD card out and view it, it might give you clue. Actually where it took of from etc.
Rod ..
Reactions: Cafguy
Thats for sure I have my info on my SD's!
Reactions: RodPad
I was about to look if there is sticky etc. for this main thread.Thumbswayup👌
Rod ..
We found a Mavic Air with the serial number 0K1CGAMRAJ1GU9. How do I find the owner?
If you look on the SD and there are photos, check the Exif date for any photos it may have from a home or yard. The Exif will have the Lon/Lat and you can look at that on a map giving you the owners home location.
Reactions: RodPad
Kazetta
