Mavic air getting lens moisture problem, any solution for that
Bhalchandra_j
I have a mavic air drone, after fly lens getting moisture problem, so I get footage foggy, how can I remove that moisture, pls help me
Apparently you have applied and tightened the lens in a really damp environment. Remove the front lens (unscrew carefully), wipe all dry (wet wipes used for applying screen protectors onto phone displays work great) and reapply the lens in air that is drier, e.g. under an AC that's blasting chilled air. Tighten the lens. This should trap drier air in-between the lens and the camera.
If the moisture is forming on the outside of the lens you can try applying a car-windscreen anti-fogging coating, they're not expensive.
Hold it up to the sun directly for a short time - once the lens warms up it will evaporate - let me know if it works - works on my mp
Dont fly in fog or moist areas?
RTLflyer
