You always give great answers. Very helpful indeed. Thanks for your swift reply I appreciate your help.Connect the Air to the app and go into the Editor. If you choose a photo or video you should be able to download the data from the Air to your device.
The Air comes with the internal card set as the default. You can change that in the go app settings.
Do I need to use any cables to do this or wirelessly?Connect the Air to the app and go into the Editor. If you choose a photo or video you should be able to download the data from the Air to your device.
Brilliant thanks, I did it using the cable as I was a bit unsure how to do it with the app. Now I know thanks again [emoji3]Here is a visual to help although it is from an iOS device so the Android version may have slight differences...
