Hi BrianIn the menu there is a specific setting for picture type for Panoramas, quite separate from the general camera setting.
When the camera is in Panorama mode tap the 3 dots at top right of the screen. In the menu that opens select Camera and you will see the Panorama section where you can select which type of file you want.Hi Brian
Can you please outline specifically where in the menu this setting is?
It makes no sense to stitch RAW, as things like exposure and white balance would not be normalized between frames (otherwise it wouldn't be RAW) resulting in a useless panorama.Are you talking about it auto stitching into a jpeg? Cause if you select raw it saves the individual files on the card to raw but the auto stich it does is always jpeg. (Unless a update changed that and I didn't notice).
