Mavic Calibration woes...
Mr Watton
Newcastle, UK
Has anyone ever got the calibration screen to work via DJI Assistant 2 on Windows 10?
I just keep getting a message to turn my Mavic off then back on again and ive lost count how many times of attempted this :(
See my youtube channel below to see im trying to follow the on screen prompts...
Mr Watton
Reactions: dadjvs
Mr Watton
Just out of curiosity why are you calibrating it? Also, is that a glass of Scotch next to you in the video? ;)
Ha Ha, the way things were going I wish it was scotch !!
My curiosity was to make sure it was calibrated as ive been getting odd areas of footage where there's distortion on darker images no matter how much i press focus :)
You must be too used to doing things on a tiny phone screen!
Why are you trying to calibrate without using the app FULLSCREEN?
Yeah i tried the full screen option too. I had that small screen on actually because the assistant opened something behind the scenes when i was downloading the flight logs. Good shout tho.
Please correct me if I'm wrong, but isn't that calibration only for the Vision Sensors?
Reactions: gvg3
yep just the front collision cameras
that is why you cant calibrate when the calibrate screen is too small
Just to clarify, full screen doesn’t work, and message of “reboot the aircraft”
Normally Vision calibration is only needed after a NASTY crash.
If it was for that, i wonder why it doesn't tell you thats what its for :(
*edit* just saw your other post. Ill see what else may fix the issue then. Thank you.
Cheers Anthony. :D
I just remembered, I had to calibrate my sensors one time. And had similar issues to yours when I tried it on a large screen desktop. I tried a different computer and it worked perfectly.
DPR5850
