This may seem a very basic question to very many of you who are clearly experts in such matters, having read so many excellent posts on here, but I wanted to clarify how to use ND filters correctly on my Mavic.
From what I can gather, ND filters are used to reduce the amount of light entering the lens when shooting video, enabling the shutter speed to be reduced, so that ideally it can be double the frame rate chosen eg at 30fps a shutter speed of 1/60sec is desirable.
So I fit my chosen ND filter and then I gather that an ISO of 100 is best (to avoid graininess?) which I assume I set manually. My query is, do I also set the shutter speed manually?
If that results in an image that is too dark, do I use the right hand scroll wheel to lighten the image (which must alter the shutter speed and/or the ISO as the aperture is fixed on the Mavic) ?
Or change filters?
Again, apologies to those of you to whom this is no doubt a very basic question!
Or change filters?
