Mavic doesn't show as USB drive when plugged into Win10
HFMan
COFPV
I installed DJI Assistant 2 and disabled signed driver enforcement (I'm on Win 10 64bit). Assistant runs fine, connects to the Mavic, can communicate with the Mavic, etc. But two problems:
1) I understand that with DJI Assistant 2 v 1.1.0, you can simply download the .DAT files by going to the "Drive" that appears in Windows Explorer when you power up the Mavic. No such drive appears. I have to download/extract/compress the .DAT files via Assistant 2, which is a bit of a pain.
2) It used to be that you could select just the Flight Control and NOT select the Vision Module file (the Vision Module files are not needed when just looking at flight control information. There appears to no longer be an option to select/deselect the Vision Module file.
Has something changed recently? Anybody else have this working properly on Windows 10?
After you select the "Flight Data" option the disk drive containing the .DAT files should appear. Like what is described here. I haven't tried this on Windows 10 though.
Don't know what happened to the Vision Module stuff but it doesn't get included in the FLYXXX.DAT file.
Nope, no drive appears. All I can do is look at the Flight Records tab, which is a pain. Supposedly the latest Assistant should allow you to directly get the Flight Data via the USB drive that should appear, which does not. I checked Device manager, and everything is green, no driver issues.
Birddog495
