Mavic Mini able to work with the DJI Go (4) app (at least on Android)?
jama42
USA
I'm a prospective Mavic Mini user and heard that the DJI Fly app doesn't support the "local data (only)" mode--not sending your data to somewhere via the internet.
So I was curious if the Mavic Mini would work with the DJI Go 4 app on Android.
(Separately, I'd also like to know if it's true that the DJI Fly app (still) doesn't support the local data only mode.)
As a new MM owner, can you explain what you mean, from what i know GO4 does send your data if you hit synch flights in the app menu, and also if you use a firewall app the GO app makes dozens of connections to various websites
Ah. I thought I heard the Go 4 app supported an optional local data mode. I was just wondering if the Fly app had the same support.
I did hear that at least the Pilot app supports local data, but I don't think it supports the Mavic Mini.
Simple answer: GO 4 does not require an internet connection and will use maps from cache.
cbooth
