Mavic mini can't take more than 13 secs capture
Dantescryz
Portugal
Hello all. I got a Mavic mini and can't record more than 13 secs most of the time. I have lots of space on memory card and usually flight on wilderness. What can be the problem? One day I forgot to put the SD card and could record way more.
The mini doesn’t record ANYTHING without the SD card
Reactions: Jack0202 and Ang
Without sd card you CAN'T DO ANY quickshots. You can take pictures and record still BECAUSE of the phone memory
but that will be at a lower resolution- plus if you're experiencing signal issues, the interference will show in the video as it is being streamed/saved to your phone via the wifi. Easy enough to get an SD card ;)
Reactions: Dantescryz
Reactions: ff22 and Lurch003
virtualkev
