Mavic mini old vs new props
  • Thread starter Thread starter Deleted member 109934
  • Start date Start date
If the rear motors are maxed out earlier you risk a blow-away case with anything but the calmest wind. Do you tests before proper flights.
I'd really like to observe a side blade profile (close up) of those CF props compared to regular DJI ones.
when it stops raining, this weekend. My friend has a mini also. we are already talking about doing a side by side comparison. I did a flight time today under my roof of my front entrance. time from starting the motors till it landed was 23 minutes 42 seconds. with 4% battery left. started with 98% I'm working on a video with some telemetry. sound level ( just used an app for the apple store. was around 77db. the area is some what enclosed.
Reactions: fificap
How do add the telemetry data to your video?
the software is called dashware
there is a learning curve on this.
also you will need to get the data for the software. I use airdata. to get a csv file.
the gauges can be found online. people made them up. I've never tried. I just find one i like and change it a little to fit my need.
Reactions: TDZHDTV
some more test of the Carbon Fiber props for the Mavic Mini
Reactions: m80116
I went back out today . The weather was great. A little tail wind going out. I'm not seeing any better time in flight. but it does seem to cut through the air easier. whole flight was in P mode.
I was watching the amps and it seem that the amps are a little lower than the stock props. I'm still uploading the video so give it till the morning to get a good video quality.
Reactions: m80116
Huey0315
