Mavic Mini Prop Holders and Protectors
TruGreen
Hemet, California
I found these on the good ole' Ebay. Shipping from Hong Kong took a few weeks. Must say I'm impressed though. They are 3D printed, but fully cover the motors and props. Perfect for pocket carry so they blades don't snag. Mini does fit inside the Fly More case, but it a tad snug. So when removing the Mini the holder stays in the bottom of the case, which isn't really a bad thing. Over all I'm happy with these and they deff will protect the blades better then them flopping around.
79791504_607647046644523_134990813523345408_n.jpg78988302_2594894190578806_5507416025127190528_n.jpg79665055_573326976784101_5259676423093747712_n.jpg78699388_1393802954132121_8445199983740715008_n.jpg79919069_2491964907707774_447040721816387584_n.jpg
Those look great. They dont ship to India, and I cant seem to find them elsewhere. I'm sure they will come up on Aliexpress sometime.
do you have the fly more case? cause with the bottom props like that i dont think it will properly fit the case and if it does fit. it may be unwanted stress and pressure on the blades.
fits perfectly inside the fmc case. no stress at all.
Thanks for the tip! I like the closed ones as well - to protect against pocket lint etc.
Tru Green - where’d you get the profile shark face? Way cool!
Thanks,
Mark
Thanks,
Mark
shark decal
stock is red. but i had messaged to see about changing the color and they said was fine just leave a note with the desired color. i did also need a trim a bit off the front. i left the gimbal cover installed while i placed the decal then just traced and cut to remove the extra stuck to the cover
That's awesome! Thanks for sharing. I'll order a set once the seller is back. When I saw your original post I thought the decal was just on the arm of the Mini. Cool to see the whole thing! Also going to order a set of the prop holders.
Thanks again,
Mark
Reactions: TruGreen
iqbalNananannama
