Mavic Mini prop holders that will fit in the Fly More Combo Case?
easyheimer
Bristol CT
Looking for a good prop holder that will allow for the Mini to fit in the Fly More Combo Case without any issues.
Thank you!
I really like these prop holders. If you have access to a 3D printer I would recommend this option. I was able to have the prop holders printed at my district library. It cost $1 because that is the minimum charge.
I tried a couple of different types but these seemed to work the best. They don't warp the props and fit into the Flymore case while attached to the mini
I have the same ones they'll work on the upper props but the case is too snug to use them on the lower blades. But them once in the case the case itself is protecting the bottom props. I got mine on Amazon and they were sold as a pair so out of the case they are good for the top and bottom.
My only concern is that they are very snug and you have to stretch them to get them on.
I always worry that I'll damage the props while trying to protect the props.
Just adapt the case with an exacto knife or a dremel...
coregambit
