Mavic Mini Prop Replacement
Glen466
Canada
I am new to the Sport.
I have about 6 Hours Flight time on my Mavic Mini
I was wondering if there is a recommendation on the Time to Replace the Factory
Props. I noticed a small amount of vertical play at the hubs.
as @Starz said the play is normal the main thing is to check for any damage to the blades such as nicks or cracks ,and also there is no distortion from being in the case
Ditto the play being normal.
OMM's "distortion" is a flattening of the blade so that there is a loss of pitch and or a reduction of the curvatures from front edge to trailing edge. It may be useful to open one of the spare prop packs and use the blades in there as standards for assessing the shape of the fitted blades.
Note change blades as pairs, not singly and do not mix and match old 'good' blades to form new pairs
There have been reports of folks going months or lots of flights with the original props. Just depends on how you treat them, I guess.
My DJI Fly app told me to replace the propellers on the back left side of my Mavic Mini and even had that side blink. I did and the warning went away.
Reactions: shaneb50
jlhdez
