Mavic Mini skin template
Im not sure why, but when I cut this on the cricut the size was not good. I exported it from Illustrator to SVG. Maybe I had a scaling error.
No templet, all free hand, and a little time. Heat gun also helps. Just be careful to use the heat gun sparingly, and dont heat up the area to much to avoid damaging the drone. Just used some carbon fiber wrap i got from autozone, and razor knife. Once it all was applied, went through with the heat gun again, and razor blade to touch up little mistakes.
Reactions: shaneb50
Wow very nice indeed [emoji2][emoji106]i like it
Here’s the controller template with a ruler (in cm) for scale. I will make an actual cut file (for silhouette/cameo) when I have time.
Also have the body template but I cut an edge off when I scanned it so I’ll have to redo that later.
Please note it’s missing the tiny little circle cut outs for the battery lights.... I didn’t weed them properly when I pulled it off the backer paper. Sorry!
Did you ever make an svg of this? Working on it now and just running into troubler with flexi
DJI Mavic Mini Skin template.pdf is to large.
Does anyone have an adapted version for the Silhouette Studio program.
Reactions: Iamlegion
Hello do you by any means have the silhouette file for the body? thenx
marianosch
