Does anyone notice if the signal indicator shows a weak signal when you get the warning? Mine always seems to show full bars regardless of actual signal strength.
I have gotten the weak signal warning when I still had a good video link and the signal indicator showed full strength. The weak signal warning was just momentary. I rotated so the controller was properly facing the drone and everything was fine.Does anyone notice if the signal indicator shows a weak signal when you get the warning? Mine always seems to show full bars regardless of actual signal strength.
Note that there are 2 separate signals involved here. The first transmits from the remote controller to the drone and carries control instructions to the drone. The 2nd is a transmission from the drone to the rc. It carries the video downlink. Generally, it is the first to fail, probably because it is trying to carry far more information.
