Mavic Mini
dpetak56
River Vale, New Jersey
I received the message that my propellers are turning too fast. Changed all 4 and after 10 minutes of flight I get the same message. I will land, reset everything and take off again and get the same message apporx 10 minutes into the flight. Any ideas why this is happening? Thanks
I just saw a You Tube video on this issue. Apparently it’s not a prop problem but something in an update. If you go to DJI’s download site you’ll see the latest update. That’s supposed to fix it. Lots of opinions out there. Good luck.
I had this issue and found different reasons why.
Like mentioned above, make sure your software is up to date. If you have a real computer I recommend the software DJI has to update all your equipment. I’ve read both “yes“ and “no” to battery updates. Apparently other DJI drones require battery updates, while the Mini does not. I cycled through all 3 of mine while my Mini was connected to my PC just to be sure. I didn’t see any updates.
Another solution was replacing the props on the rear motors. Why just the rear? That’s because the Fly More case for the Mini is a bad product. Long term storage of the Mini folded up results in pressure being applied on the rear props which flattens them out. More flat = motors turning faster to create the same amount of lift = error code on DJI Fly app.
I confirmed my software, changed my rear props, and do not store my Mini folded up anymore. Since doing those things, I have not received that error code.
Reactions: Jane and gspell
maybe a stupid idea, but does it help if u disable payload? payload is a function that the gives the motors more power if they gotta carry something (the protectors usually)
dcsmith
