Mavic pro crash. Gimbal repair
Infinite 1
So, risky maneuvers under trees and low battery don’t mix. Crashed Mavic pronto a tree branch about 8 foot up. Everything powers up but looks like I broke part of the gimbal. Any help on what this part is and where to purchase. Also any exploded diagrams of the gimbal assy out there?
thanks!
thanks!
Vibration plate board? Hard to see but that’s it looks like to me. Gimbal is secured to the vibration plate with two screws that’s connect the very top of the gimbal to the board which is suspended via 4 rubber bands. You’d be real lucky if you broke that and nothing else. Usually that ribbon cable needs to be replaced too but you might be able to replace the vibration board without opening the drone so try that first and see if she works properly first.
For DJI MAVIC PRO,Aluminum Gimbal Vibration Plate Board Replacement Mount Part
You have broken the piece of the gimbal plate that attaches gimbal to plate.
Two screws hold the gimbal to the mounting plate.,
Can’t tell if ribbon is torn but doesn’t look like it.
See the two holes on bottom of plate?
U need the piece that mounts gimbal to plate via those two holes
Jarrcor
