Mavic Pro gimbal issues
Pythons09
Just had my first bing,e. 6 foot in the air.
When I checked it 2 x props needed replacing and there was a small dent but nothing appears wrong anywhere else.
When I went to use the camera I noticed I couldn’tmove it and couldn’t calibrate it. Got a message along the lines of “camera too heavy check gimbal”. Upon closer inspection it does appear that the gimbal has popped out of its mount. Video etc can still be obtained but I don’t want to use it without having it repaired.
Does anyone know a quick fix or does anyone know how to repair this?
Obviously I’d fix you up for your time in some way.
I’m in Caroline Springs in Melbourne west.
Cheers
Shane
If you're handy with a screw driver, it should be an easy fix. There's 4 rubber bands holding the gimbal to the mounting plate.
Otherwise I'd recommend Thunderdrones.
Reactions: Former Member
Had a look and it appears they are all ok. I think it might be a gimbal ribbon issue and I’ll have to get it replaced
Have a look at this vid' as it may be as simple as the Gimbal mount plate needing to be re-positioned ...
Reactions: Hardgainer
Adam_16180
