Problem? Gymbal sending error reports, gymbal overloaded and gymbal shake error. Gymbal will not calibrate or move l.
Was unit in a crash? Yes
What have you tried so far? Dried it once and have put it in rice
What device are you using ( iphone , ipad, Samsung , etc)? Samsung
What firmware are you running ( aircraft, remote controller)? Newest
What Go app version are you using? Newest
Any modification? (if so what) it's stock
Did you change anything or install any apps? (if so what) no
Was filming snowboarders and flying it from my hand because of the snow. Changed batteries and went to take off again but on start up a blade hit my finger and I dropped it into the snow camera first. I cleaned out all the snow and water with a cloth. I then took off and it came up with gymbal shake error so I went to land it again. Before the drone landed the gymbal went back to normal so I flew it on one more short run before putting it away. On arriving home I unpacked it and looked around the gymbal to check for water. There was one or two small droplets so I removed them and started it up to see if it was still working. It flew fine but was getting gymbal shake error followed by gymbal overloaded the camera is working but the gymbal control does nothing however the gybol moves from side to side and up and down without me controlling it which is strange. tried a gymbal calibration in the vague hope that this would do something but it got 31% in before failing. I have now put it in rice in the hopes that will sort it out. Anyone had anything similar or got any tips as to what I should do next?
