Mavic Pro Platinum Vision Sensor Issue
EHuffman
Dayton Ohio
Hello all, I have a Mavic Pro Platinum that has a vision sensor error. It flies perfectly fine with the exception of obstacle avoidance not working. It says the left front vision sensor needs calibrated. I hooked it up to a pc to calibrate it and the left sensor is not showing any image in the calibration procedure. I then replaced the vision sensors and that still did not fix my issue. It has been crashed once but this issue did not show up right away. My connections seem to all be secure. Do any of y'all have any suggestions on what to do next. I am very comfortable doing any work to it myself. Thanks in advance!
Most probably an issue with the zif connector being bent etc.
Reactions: RadioFlyerMan
My zif connector seems to be good, it looked perfect on the original when I replaced the sensor. Maybe I'll take a look at the gimbal control board.
Badeff
