Mavic Pro Props
skinner14
Ottawa, Canada
I'm starting a project where I use propellers. I noticed the props for the Mavic pro are two separate props, connected by a piece in the center. Does anyone know if this piece can be removed so the props can be separated (sort of like the Mavic mini)?
yes you can take them apart
Reactions: pelagic_one
In all due respect (for M2P) ~ You will have to push the pins out to separate the propeller blades. Another aftermarket supplier (Master Airscrew) uses a thread Torx fastener ... Good Luck !
ryanhafeman
