Diagram of Mavic Pro controller attached. Are you talking about button numbered 5 or camera control #12? If it's button 5 they are available online. Do NOT use glue to reattach . Button is a press on fit and comes off easily. When mine came off it also caused the functions of the actual switch to stop working as well. I had pulled the controller from the case carelessly which put too much pressure on the button. Had to replace the button pad inside the controller as well. Found the replacement button on ebay and the button board on amazon. Dji would not sell me a button pad nor would any dji dealers here in Canada.Opening the case to replace the button board is shown on several you tube videos. It's a bit of a pain as it seems like your applying too much force to get it apart but it is not that bad once you get past the fear factor. "Button board part number CP.PT.S00058. The button is listed or known as D5.
