D
Deleted member 161693
Guest
Hi !
I bought a cheap secondhand Mavic Pro M1P with a few issues, history unknown, and took the challenge to fix it in order to have fun with a drone while being broke.
The purpose of this thread is to regroup all known issues and fixes in case somebody needs them.
Here we go:
-Rear arm platic stopper tab on the hinge was broken.
Part is here 8.17US $ 22% de réduction|Arbre de bras arrière gauche droit pour Drone DJI Mavic Pro, pièces de rechange, accessoires de réparation | AliExpress (the cheapest I could find, it fits)
This video explains what needs to be done
-Fan was not working, and device was overheating.
Part is here 6.82US $ 15% de réduction|Pièces de rechange pour ventilateur de refroidissement DJI Mavic Pro, accessoires originaux pour Drone | AliExpress (again, the cheapest I could find)
This video contains a part whith the useful information After swapping the fan, it was still not working. The new fan was working when applying 4V DC. I wondered if previous owner had played with the firmware at some point.
I reflashed the latest firmware: nothing
I made a factory reset with DJI assistant: SUCCESS !
I was a bit puzzled but still happy. Previous owner probably tried to hack the drone.
-RC could not connect no matter what I tried (went through quite a few documents and videos)
Flashed the firmware on both RC and drone: SUCCESS !
-Gimbal often reported N/A in the app. I can't access settings or calibration. Most of the time, the gimbal menu is there when the drone is cold, I can access settings and calibration, but then it vanishes when the drone starts heating, after a few minutes.
-I changed thermal paste (quite cracked and brittle from overheating probably) in order to improve cooling - no effect
-I read some people had this issue after FW upgrade, so I tried downgrading (both RC and drone) with DJI assistant: no effect. I tried downgrading to earlier versions with DUMLdore, but it failed. Went back to latest firmware. Still nothing.
The gimbal initializes properly, and I can do tilt/pan from the RC.
-SD card reported as N/A in the app, except when the drone is cold. Sometimes, even when shown as missing, it mounts on my PC plugged on USB.
-Not related to SD card. I've tried many, including ones that work in a friend's mavic pro.
-I tried cleaning the SD port with a duster and some contact cleaning spray - no effect
-No chime sound on startup. I can live with it.
I wonder if the main board has suffered from either a crash or overheating. There's a guy close to my place who is able to do chip reballing (mostly for game consoles) in his workshop. But I'd like to understand which chip to work on.
Issue with gimbal N/A doesn't seem related to the gimbal or the camera, as they both work, but rather with the management interface that probably goes through a different wire/chip. I wonder if it could be a consequence of firmware tampering. I'd like to rule out all possible software causes before trying hardware. Hope is low as it seems temperature-related, but still work a try.
-> Is there something I can learn from system logs ? I've read a few of them but didn't find anything meaningful. fatal.log says things about module auth gone wrong, and 'fail to get buf for vision' service but that doesn't mean anything to me.
-> What else do you suggest ?
Regards
Here we go:
Regards
