Mavic Pro system error, not responding to RTH
Piet and Koos
South Africa
I am having trouble with my Mavic pro. I start everything and allow the drone to update the home point and everything that it needs to. As I start flying the controller gives me an error saying 'system error check app', and on the screen the top bar goes orange and says ' In flight (vision)'. With this it flies on its own, when I leave the controls it continues flying, it does not go into a hover. It does not respond to the return home command. If I loose sight of the drone and do not stop it, it will continue flying away, it is like it does not recognize the home point anymore. I have calibrated the Vision System, but I still have the same problem. As soon as I start flying it give me a message saying week satellite signal. I have had the drone for about a year and have logged 58 hours in 270 flights.
You can do only one last thing before sending it to DJI for repair. Connect Mavic and later the remote to a PC and use DJI Assistant for reprogramming the latest firmware. If this doesn't help, send it to the repair centre.
That sounds like GPS failure, which would cause ATTI mode behavior when VPS is unavailable and no RTH capability.
Reactions: Thomas B
hughesthis
